Heat monitoring...
xnyjyh
I like to find the right place to attach the wire for monitoring my 4870 card!?
Im using the Scyth monitoring system...
I dont think I have it in the right place as the tempature shows 48.9C Idle average, when it should be 77C on idle!
can anyone please tell me where to attach the wire for accurate heat measurements?
Thanks
Well PC Wizard does it.
The best thing to do is to is get a program. The new PC wizard you can view the temp.
I know there are a few other programs.
I have the PC wizard now but it dosnt seem to monitor the card!
Would it have a different name for the graphic card? I wouldnt think so...
hah very cool....Thanks for the link!!
Hmmm actually I just noticed after installing it didnt detect my card! :\
There is no installation required. Download it to your desktop (or folder of your chosing) unzip it (extract) and then just click .exe.
