Best Motherboard under $180.00
Alright, that's cool, i'll do a build later on for you.
Ok thank's, Note post above:Also the only thing i am will to change in the list is Motherboard,Cpu,Cpu fan and Video card. But remeber i have to stay in my Budget, Can be 5 or 10 bucks off but that is IT.
PLUS you get a $60 mail in rebate. So you're under the budget. :D
Just tell me if I missed something. :P
EDIT: SCREW that PSU, it probably won't power the card. Use this one. It's $10 more so budget isn't a problem. http://www.newegg.com/Product/Produ...82032&cm_sp=DailyDeal-_-17-182-032-_-Homepage
Don't like it at all.
Like i said in 2 post the only thing i am willing to change in list is Motherboard,Cpu,Cpu fan and Video card. But remeber i have to stay in my Budget, Can be 5 or 10 bucks off but that is IT.
So basically you want something more expensive, slower and not as good than what I just did?
You had a P35 mobo, I offered a P45 one with a E8400 for a combo price. FAR Cheaper than what you had for a E7200.
You had a 320 GB HDD, and the one I had came with 500GB.
You had a 500W OCZ PSU, The one I revised was a 600W. Rosewill
You had a 8800GT and the one I listed had a 9800GTX+.
Speakers, yours didn't come with a subwoofer.
SO what part did you not like?
First off i want to say to you, This will be my first built pc.
I came in here asking for some help on what Video card,Cpu,Motherboard and cpu fan to get.
How many damm times to i have to tell you that is all that i want to change on it, I am open to your idea on the power supply though.
If i wanted a Subwoofer with my speakers i would of got one but i don't want one.
It's not your money it is mine.
Also my limit is $1,100 not $1,130 almost, Are you confused or what.
The only person that seems to be any help on here is Cohen.
Well than, be my guess on buying stuff that's expensive. Like you've said, it's YOUR money that you want to waste. If you want to talk to me like that then I don't really care. I tried to help but if you don't want to listen then sure why the hell not.
Well dont mean to be an ass but is kinda driving me crazy, I am open to your idea on the power supply and the few other things i would upgrade.
computer IC
QG82945G-SL8FU
LE82Q965-SL9QZ
LE82946GZ-SL9R4
NG82915G-SL8BU
RG82865G-SL743
LE82Q963-SL9R2
QG82945GZ-SL927
ADM1014JRU
NH82801GB-SL8FX
NH82801FB-SL89L
FW82801EB-SL73Z
FW82801FB-SL7AG
NH82801HB-SL9MN
FWE6300ESB-SL76G
NH82801HO-SL9MM
MSN: timesyangtse@hotmail.com
skye: elaine726
Ok lets do a little comparison a 2.4GHz P4 478 vs a 2.4GHz Athlon 64 939. I can already tell you who won cuz i UPGRADED from the 478 P4 the Athlon 64 939
um yeah, the 939 was so far advanced vs. the P4 prescott/northbridge. what's your point? the 2.4ghz P4 is like a 1st gen anyway and the 2.4ghz A64 929 came out MUCH later than the P4. that's like comparing my C2D to a Barton Core Athlon XP. you have to compare apples to apples, not apples to gasoline.
Did he not say AMD compared to ANY Intel? I followed the guidelines he set lol. I coulda compared it with the old Socket A if that would so please you and yet the AMD woulda still won cuz back then AMD was ontop. That was my point.
in that case, let's compare your Brisbane against a proper CPU. i'm sure i can underclock my CPU for some friendly AMD benchmarking.
Dude... are you still living in the year 2000? If you have read my post right then you wouldn't make a fool out of yourself.
I said AMD sucks AT THE MOMENT compared to Intel.
and if you're trying to pull some AMD fanboyism at me then get lost.
Actually that was 2004. I did read your post right, you said any Intel. Is a Pentium 4 not an Intel product?
The point is AMD is just behind right now. Just as Intel was behind from 2001 to what 2005 or so.
AMD will eventually catch up just as Intel did thats how the game works.
