Kewl Munky
I got my 9800GX2, and I see no better performance than my 8800GTS 512mb. What the hell? I have my Q6600 OC'ed to 2.9ghz at the moment, and plan to go further later on. Is my CPU holding me back or something?
I've downloaded the drivers. I'd hate for this to be the issue, but could it be not getting enough power? I'm using an adapter to go from 6 pin that splits it into two 6+2 pins, but I only have only of the 6+2 pins plugged in. Maybe it's not routing all of the power to the one 6+2 end? Is there a way to check if it's getting significant amounts of power?
Is SLi enabled?![]()
The 9800GX2 is two 8800GT's slapped together into one card... I'm not sure if it would or wouldn't use SLI. See if you can enable it, see if it makes a difference.
well it does have an sli bridge if you disassemble the card
Two 8800 GTS', actually. But yeah, I'm not sure if you need to enable SLi with the GX2, so that's why I asked. My 3870X2 was Crossfired out the box, but I'm not sure how it works with this card.
try enabling SLI optimisation in farcry itself
and yeah get a better psu
yeah but he said he only had one of the 6 pin connectors in, and that it wasnt a dedicated rail , he was splitting it off something else
