64-bit versions (for dummies) - happiness vs. headaches?
im not sure
on 2 different MS sites, it says yes, then no. Know for sure it doesnt work on 2000 pro, so i would assume probably not.
wonder what the effect of /3gb on xp x64 would be (based on server 2003)
well im using xp pro x64...
iv had no problems except the intial setup of drivers for sound and modem...after that everything runs great and fast :)
even install printers and and driver for everythign else works fine with no complications yet.
my two cents
yeah the trick with drivers is if the xp ones dont work, try the server 2003 ones
vista 64 has better driver support
I use x64 Ultimate only because it was given to me. I only have 4GB RAM so it's not like I really need it to utilize a bunch of RAM. It seems very stable but I don't really know if it seems any faster. I do not run any 64-bit applications though. Drivers have never been an issue with my hardware.
Just a quote: "64bit is faster yes"
"64bit is really useful for video encoding and stuff that takes 100% cpu and takes long time"
Thanks
SO, if you're a user that doesn't have more than 4 GB of RAM and does not run any 64-bit applications, what are the advantages of x64 over x86?
Is it any more secure than x86? Thanks.
nothing whatsoever, in fact its worse, because of its poor driver support record
if you need 64 bit apps (some scientific and server software) and / or lots of RAM, 64 bit is the way to go. Otherwise its useless.
