this has been done already in flash
Alright, I got it. Now tell me what you think about the installer.
http://rapidshare.com/files/147110280/setup.exe.html
"This" meaning what?
an OS simulation
Nice one, what software did you used?
That should be done with the final version when it's finished, not now when it's still under construction.
Just one problem I see in the installer: bad default path. It should put it in the root drive, because if it is put in Program Files some links may broke. I'll try to make that to work with any path using relative paths, but i'm not sure that it will work.
Lol, I downloaded it and tried it out, how come alex's name isn't in credits ?![]()
oops. that link is not good. At least it doesnt work for me.UPDATE
Build 4 is now available for download. Link: http://rapidshare.com/files/147650081/CTA_8_OS_B04.rar.html
It has new features and fixes, some major updates:
These are just some of the many new updates existing.
- Media Player exists, but can't be used yet
- The Stills folder on D: drive is now filled
- Alex's name is now in the credits
- (New) icons
- This one you may not like it, but an "Under Construction" banner can be seen in some places.
I don't need to. I can do that from PowerPoint without any kind of controls. Of course, no volume control, nothing except the 3 buttons (Play/Pause/Stop) and a unmovable slider.use VBA to call controls from the real Windows Media Player
Now it worksOn mine it works. It says "Still <number> seconds" and then after the timer is at 0 the Download button becomes available and it works.
Here is the same link: http://rapidshare.com/files/147650081/CTA_8_OS_B04.rar maybe this time it works.
