Yap, for me Vista is no good, i ever read that Vista is one of Microsoft failed project...
is it true ?
and, i choose Windows XP Professional, coz i still use it after i throw away Vista ( buy the pirates one )
Vista was a failure when they had the first version, but since Service Pack 1 is out, it has been a lot better! and i mean a lot! i haven't had any problems and i have seen or heard of anyone reporting faults or problems.
XP also wins thanks to the DX10 crack that works PERFECTLY. Only reason for vista to me was the DX10 for gaming but no more
that patch does not work,it does to a certian extent but its not fully DX10.
thats the reason im sticking with Vista for now or i would have gone back to Xp
well there is one bug i found last night but it a very small programming error nothing that will effect your use of vista but if you open the on screen keyboard and set it to 108 keys the cap lock button, it turns to Chinese
when vista first came out i hated it (i think most people did) but since i bought it and got used to using it, i really like it. i'd never go back to XP.
there is a disable UAC checkbox
Yeah but it doesn't work for me. It doesn't disable the full UAC.
I kept getting errors with PG2/PC Alert/G11 Macro.
I had to disable it via F8 each time...and the properties/uac was disabled.
other than the fact that vista is a RAM whore if you have atleast 4GB there is no problem at all and you get the best windows, infact the best OS, ever made. It is alot easier to use than any other, except for the fiddly tasks like changing boot pictures and stuff, but most people don't do that, so it isn't a problem at all, so easy and so good looking
