Hey, just wondering if there are specific types of spray paint I should be looking for to paint my case or if any spray paint will do....
Thanks
if you want it to look really nice, paint it like a car would be painted.
There is a process to go about this similar to how a car would be done that would cost like $20 total. It just invovles some time, sanding, and quality paint.
If it is anything like painting a car then it involves a spray gun and expensive paint. You are probably just talking about a rattle can job.
First sand it down or sand blast it will be much faster and will do a better job, use a primer wait 1 hour or so do 1st coat of whatever color repaint if needed. Use a spray gun and a compressor. Why I say a spay gun well it paints evenly don't have to worry of over painting it. I would use a car paint it can get expensive tho it depends if you want to pay that much but at the end you will have that effect you are wanting. Spray gun gives you a even coverage and the outcome will be much better and it will look alot nicer then if you were gonna use a spray can, plus with spray can you will need to get caps for it. Check below to see how he painted it and what he used. One more thing if this is you first time spay painting then I would wait until you know something about it. I would first get ur old case that if you have a old case you don't use and work with that.
http://www.youtube.com/watch?v=Q_YY83dGbEI
If you dont want to waste alot on it or dont have the supplies go with a case film they got tons of colors, carbon fiber, with flakes without. Here is the link. Check bottom of site it has the film, there are also video of how they put it on and before and after looks kinda neat. Hope this helps.
http://www.mnpctech.com/casemodstore.html
