Yes. Not much more than XP, but in terms of usability, reliability and/or safety it's at least as good as XP, granted it takes a lot more resources to run. Some features of Vista I really like over thsoe of XP, but like I said in the other thread, personally either is good and the only reason I'm using vista is because nowadays all computers come with it.So what i am asking is, is it good//safe?
i used vista on a laptop for about a year, and theres no real benefit to switch from xp to vista IMO, microsoft has appearently extended xp till 7/09 on computers from suppliers, so you can pretty much just skip right over vista and wait for windows 7.
vista worked pretty decent for me, but you'll need a good processor and alot of memory i'd say no less than 3 gigs.
Well, Vista was horrible because it had many crashes and so on, but SP1 fixes most of the problems.
You could try it, and if you don't like it switch back to xp.
I really want to know what you guys are doing that 'makes vista not work'.
I mean, how handicapped are people? Vista isnt a great o/s but it works, it doesn't just randomly crash, and nobody ever gives a real reason----uhh it just doesnt work.
I've used Vista for nearly 2 years now (beta included) and its just not as bas as alot of you guys claim.
Why don't alot of you just stop jumping on the anti-vista bandwagon just to sound cool..
im running vista with 2Gb with no probs and have ran it with 1Gb
The more memory you have, the more memory Vista will use. When I had only 512MBs of RAM, it used around 300-350MBs of RAM; when I upgraded to 1.5GBs, it started using around 700-800. My mum's laptop (it's got 1GB RAM) uses around 500-600 or RAM after startup.i never said that 1 or 2 gigs would cause a problem.. i had 2 gigs in mine and it worked well but it needed more memory, the meter was still over 50% at idle, i had nothing on it and uninstalled all the programs i didnt need
