Windows Vista- Sound Help!
JulieBaby
Hello everyone :)
Recently I had some problems with my pc (Windows Vista). I dont know anything about fixing computers but I put in the disc that came with the pc so everything could be reset. Thankfully it worked and I saved myself a few dollars and didnt have to take it to be repaired.
But ever since I put that disc in my speaker dont work. The pc says 'no sound device installed'. Everything was working fine before.
How can I get my sound back? My speakers did not bring a disc of any sort.
Thanks!
Hello everyone :)
Thanks!
You most likely need to reinstall your sound drivers.
If its a dell or HP, then go to there website you should be able to find drivers.
If its a custom built PC(doubt it from the sound of it) then find the driver CD that came with the motherboard or download them from the manufactures website.
