I unchecked some items from my System Config and now my burner will not work. The drive is there but none of my programs will burn a cd. So my question is... what needs to be checked in system config for my burner to work correctly?
Now that moron has offered his nonsense
Who you taking to now? Yourself? or simply digging at straws again?
You seem to forget real fast that a lazer can go in a drive at any time as well as seeing a flaky cable act up. As far as the msconfig is concerned disabling items in the services tab without first checking off the "hide all microsoft services" box is asking for problems.
The question for drewski at this point would be can you still read from disks when inserted into the optical drive? Here I can go into the msconfig at any time and uncheck everything and still see disks burned with various programs.
Like I said, Then you start off on a incoherent rant!
I don't actually care what you muttered in post #7. Try staying on the original topic when on a thread instead of making lame remarks.
There is (really) something wrong with you!
So... his burner works, he goes in and disables something, and then the burner stops working. What is most likely the cause? Something he disabled or the drive/cable broke (he also can see the drive in windows)?
What about reading from it?
