AUTOBOOT2000
Is ATi a safer bet? I heard they are faster and stuff...
the diff between ati and nvidia is ati does not melt.
Okay, I think I found something I want.. How is this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
Will it work with my setup, and fit? It takes two slots, I just want to know if this is as good as I think it's. Great reviews and everyone says it's the fastest thing to having x2 4870's..
Is what I choose compatible with everything, so I am good to go to buy that with everything else I have?That video card you selected is good. I think the ATI video card I recommended is better value for your dollar. You won't be disappointed with either video card in my opinion.
I personally would go for the GTX 260 C216 Black edition by XFX. On most test it out performs the 4870. And some tests it out performs the 4870x2. Mobo, I would go for the ASUS rampage formula.
heres the 260
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150330
EDIT. I should add the rampage comes with 7.1 surround sound PCI card.
Thanks for the suggestion, but I will stick to one GFX card. Two is a waste to me, maybe in a future build when I move to i7-technology or better, in a year.Should be compatible, I would get this Motherboard instead though. Mainly because it has Crossfire support, so if you ever decide to buy another video card you will be set.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
And do you have an OS you can use?
Two things sir.. Is the one you suggested (case) as good as mine, I picked mine for the GREAT cooling it provides.Case: XCLIO Windtunnel Case - $99.98
Power Supply: SILVERSTONE ZEUS SST-ST65ZF 650W - $69.99
Motherboard: GIGABYTE GA-EP45-UD3P - $129.99
Video Card: SAPPHIRE 100259-1GL Radeon HD 4870 - $289.99
Processor (CPU): Intel Core 2 Duo E8500 - $188.99
Ram: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 1066 (PC2 8500) - $59.99
Hard Drive: 250GB Western Digital + External 250GB SeaGate (Free - Already Own)
All the chosen parts in this list are compatible. There is only one thing I would change on this list. Your case is good but it is overpriced. $100 is too much for a case.
Look at this case:
APEVIA X-Plorer ATXB8KLW-BK Black Steel ATX Mid Tower Computer Case - $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144102
Also, if you don't have a Windows Operating System installation disk you will need to buy one.
But no, I don't have a OS I can use.. That's expensive. I don't want to think about it, cause I'll have to get 64 edition, but I don't want Vista. I want XP-64 Professional.
And second, I don't have a 64 bit OS. So I am screwed, have to buy a over priced garbage disk. Since I shouldn't use my 32-bit version of XP-Pro.
