All right let me get this straight. If I were to connect to my existing power supply, which does not have a 6 pin connector, would I have to use the included wire with the two 4 pin molex connectors? Would both the molex connectors need to be connected? Or is this wire only for newer motherboards?
By the way, I will switch the power supply these are just hypothetical questions that I hope will help me to understand.
Any more info will be great.
Thanks a lot
Nick
The P8 connector has nothing to do with your video card, its the 4/8 CPU power connector/ are not interchangeable. If your P/S does not have the 6 pin PCIe power connector you use the supplied 6 pin/molex adaptor with 2 4 pin molexs connected, then plug into your video card.
