how does that make sense?
so i go to the website,when im prompted to download the installer i cancel that to get an "offline install"?
how can i get an offline install if i dont download the installer?
You're right its worded badly, i copied it from what the guy with the same error as you said worked, and my guess is that he means is when the automatic download box comes up click cancel then look for the thing the little box on limewire that says something like "your download should start automatically, if it doesn't click LINK" i dont know why they would be different it doesnt make sense to me but thats what the guy said. figured youd want to give it a try if you still cant get it to work.
