well the 2 gigs is for ddr2. with i7 build he is going to need ddr3 which is much more expensive....
What do you mean... btw let me post my initial build so you guys can critique it if you don't mind
I'll wait for the newyears to pass, then see the reviews on the new AMD quad CPU
I have decided to stick with air cooling (unless informored otherwise)
Ill go with the 1000rpm raptor drives (500g minimum, 1terrabite maximum)
8 gigs or RAM
Now I'm not sure on how much wattage this system will pull, so to be safe Ill hitch a 1000 watt PSU on it... I'm eyeing this one by corsair
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007
Not sure which Mobo to get just yet though
I will ignore the 4870 X2 and go for the GTX 280 (again unles instructed otherwise)
I wanted to get a top-end case (CM cosmos S), but weight might be an issue
I was going keep the sound integrated... but was not sure if a sound card would be ideal for a media pc... wow, I might have answered my own question
but then again what do you guys think?
He has the extremities as far as I know (keyboard, mouse, LCD monitor) but I might but a monitor, just a 22 in widescreen...
So what do you guys think, where can I maximize the money I have on this build (no matter how large the budget is
