What would you add or change?
i'm screaming in my head right now, but don't get those ssd's whatever you do, these are much better: http://www.newegg.com/Product/Product.aspx?Item=N82E16820167005 and i would suggest getting a raid controller for better read/write times: http://www.newegg.com/Product/Product.aspx?Item=N82E16816131003 as for a case look at this place: http://www.mountainmods.com/ as for your watercooling parts, look at this place: http://www.petrastechshop.com/ oh, and corsair is coming out with some 2ghz ram that runs at the 1.65 volt limit, probably going to be some of the fastest ram around
edit: look here, this might help you decide what you want to do when you actually build it: http://www.xtremesystems.org/forums/forumdisplay.php?s=&daysprune=&f=286 i would also suggest these fans if you do use radiators(and a fan controller too): http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054
Awesome! Thanks for your suggestions.
Quick question, I was looking over mountainmods and im pretty much lost; theres just so many options and choices, I have no idea what to look for. :o
If you could give me a little guidance it would be much appreciated.
Edit: Also wondering if anyone knows which of these two would be better:
http://www.petrastechshop.com/dadenddfucow1.html or
http://www.petrastechshop.com/niplekfucowa.html
Also would these work: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231240, if so I'll just buy two sets of em and just let that be that. 6gigs of RAM would plenty for now.
1.they make a 6gb kit of the pi
2.those blocks perform about the same, you might as well go for bling
3.depends what you want, ascension is like 18 wide by 24 tall by 18 deep, u2-ufo is 18x18x18, the towers(18 and 24) are 9 wide by 24 tall, by 18 or 24 deep(i think)
edit: oh, and be sure to setup a build log over here when you do get everything :D
didn't notice you were talking about 2000mhz stuff, then yes, you would have to buy two kits. and on the build log thing, if you got my pm, then thats what it is
Looks good.
I guess all I need now are additions if anyone can think of any :)
