just a noob
Well-Known Member
how much for a pair of gtx 280's in sli?
Power Requirements:
Non-SLI: 630W Minimum Power Supply
SLI: 680W Minimum Power Supply
One 6-Pin Power Connector
One 8-Pin Power Connector
I'm trying to decide between the 8800GT, the 9800GTX+, and the GTX 260. I have 2 12V rails running at 16A each. I know the PSU will run the 8800GT. Do you have the specs for the 9800GTX+ or the GTX 260? It's a 500W PSU.
Minimum of a 500 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 36 Amp Amps.)
Minimum of a 450 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 24 Amp Amps.)
Minimum 550 Watt for SLI mode system.
(Minimum recommended power supply with +12 Volt current rating of 30 Amp Amps.)
the 9800gt needs to be added.
There's alot of the new ones that's not on there.
Just for the record, I'm running 8800GTS SLI on a 520watt PSU.
That's cheating though, that's a Corsair PSU you're running.
