ahh, must have missed that
Do you have any extra Case fans?
does this happen to be your card?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150316
theyre talking about it here,
http://www.bjorn3d.com/forum/showthread.php?t=25639
only i was looking to what software you could us to control fan speed.
if ntune will allow you then pump it up to full speed,but on some cards ntune doesnt allow you to change fan speed (like mine)
vid cards do get quite hot,those temps of your aint realy that much to worry about however i wouldnt like to see my card get that hot (thats just me lol)
your idle temp is my load.
What software do I use...I don't think nTune works....?
i use asus smartdoctor...i doubt it will work with your card but you could try![]()
