cpt.obvious
I'm having a real trouble with overclocking my 920 with the Rampage 2 Extreme.
What are the issues you are having?
raise the voltage on the processor.
I have no idea how to OC the i7's, but, take the ideas from OC'ing any other CPU. Start at where you're stable, which is 3.4, right? Then knock it up a little, to something like 3.5. If it isn't stable, raise the voltage. Then just repeat the steps.
You'd see better results and it'd probably be more stable (not to mention, safer) to OC through the BIOS.
lol, Nope. Trying the settings you have no in the BIOS and then up them, I'm sure you'd have a much better chance at clocking that thing higher.
Hmm, look at this. SO what should I put things too. This is what it is at now. 2.93. When I had it to 3.4 it was running fine till I put it underload. Than I got a BSOD. I just slowly kept turning up my BCLK Frequency to achieve 3.4, i forgot what I had the CPU voltage set to.
