I've just put together my newly built rig (first time build and it survived having power supplied to it yayay)
So I need to install some operating system better than the windows 98 which is all I have, and figured why not try hooking up the new windows 7.
I'm trying to do this without a burned iso/dvd and using image mounting software instead. Trying to throw in my current system's HD into the new one to load the windows files.
Well I went ahead and downloaded the 3Gb ISO file which is half my HD,(It took 3 weeks to download) and went to mount it first with magicdisc (Failed to mount) then with PowerISO, it mounted but when trying to run the setup it then said 'file expects newer version of windows'
Is this game over or can I win?
Aren't people installing windows 7 on fresh/blank systems??
