JTM
I currently have an HP Pavilion Elite m9340f. The mobo is here. The mobo is a micro ATX configuration from looking at the mobo specifics.
My plans were to buy a case, psu, and a 4850. I would be re-using the ram, mobo, cpu, hdd. The reason why I can't do this in the HP case is because it will most likely run hot. I looked on Newegg and didn't find a tower that seems big enough that is compatible with MicroATX.
So my questions is what options are available and do you think it is worth it to do the case swap/upgrade.
My specs are as follows:
Intel Q6700 @2.66
6 gig DDR2 800mhz
750 gig sata 7200rpm hdd (Seagate)
Mobo as described above
Nvidia 9500GS
Intel Q6700 @2.66
6 gig DDR2 800mhz
Nvidia 9500GS
