um no idea only ever used air wats ur rig running
try something by swiftech-they do good kits, stay away from the cheap kits
most cheap kits are only a fraction bettr than a good after market air cooler, tell us your price limit and where you will be purchasing from
Thanks for the adviceand im not to sure on which kit to buy could you do any recomendations for me?
Wow expensive but im sure i could get that if i saved up is it much better than fan cooling yer?
there are cheaper kits-if price is a problem you could buy seperate, bit by bit...
yes it is better but only if you plan on overclocking to the point where air cooling cant handle the heat..
in a normal computer its useless really
not sure![]()
Haha owell not to worry..
I said something like it was a bit expensive and you said there were cheaper options? But i just had a thought if im only cooling my CPU with water cooling then why not just buy individual? Cheaper right?
it really depends on the quality of your componants, you can pay £60 just for the cpu water block and £70 for the water pump-thats £130 already and there is more to buy....
depends on your budget and the quality componants you want
