Z zer0_c00l Active Member Feb 18, 2009 #22 well if you have it in your budget i can put a couple up for you http://www.newegg.com/Product/Product.aspx?Item=N82E16835154002 without lights a little cheaper http://www.newegg.com/Product/Product.aspx?Item=N82E16835154002 http://www.newegg.com/Product/Product.aspx?Item=N82E16835101024 http://www.newegg.com/Product/Product.aspx?Item=N82E16835101018 http://www.newegg.com/Product/Product.aspx?Item=N82E16835101010 cheaper but good http://www.newegg.com/Product/Product.aspx?Item=N82E16835185125 still cheap http://www.newegg.com/Product/Product.aspx?Item=N82E16835118036 Last edited: Feb 18, 2009
Z zer0_c00l Active Member Feb 18, 2009 #24 spearlymatt said: Shouldn't you need a case? Click to expand... he has antec 900
S Sean89 New Member Feb 18, 2009 #25 Thanks zer0_c00l for everything, gonna go with this cpu cooler will look nice in my case. http://www.newegg.com/Product/Product.aspx?Item=N82E16835154002
Z zer0_c00l Active Member Feb 18, 2009 #26 no problem glad i could help and thats a great cooler have fun with that computer
S Sean89 New Member Feb 19, 2009 #27 one last thing you sure this cpu cooler will fit in the case? reading the reviews ppl said they had to lose their side fan have another cpu cooler with blue led u recommend? http://www.newegg.com/Product/Product.aspx?Item=N82E16835154002 i guess ill go with this one unless u suggest a better one: http://www.newegg.com/Product/Product.aspx?Item=N82E16835101010 Last edited: Feb 19, 2009
Z zer0_c00l Active Member Feb 19, 2009 #28 it will fit in your case easy..... i used to own an antec 900 big dusty monster i loved it!! Last edited: Feb 19, 2009
