Hello, My brother just got me this graphics card as a birthday present http://www.newegg.com/Product/Product.aspx?Item=N82E16814102810
IT is very good but my crappy computer has only a 300w power supply.
I want a power supply that will run my comp which has only an audio card in it. With my Video card of course. It has to be at least a 500w which i heard i may want to get something a little bigger. I want the PSU to fit in my case and work with my MoBo.
Some links about my computer: Gateway GT4016
http://support.gateway.com/s/CASES/WME1T493-001/WME1T493-001iv.shtml
http://support.gateway.com/s/PC/R/1008842/1008842sp3.shtml
http://support.gateway.com/s/PC/R/1008842/1008842nv.shtml
This is the first thing i have done out side of video cards.
Also while this is not on this board can you reccomend some good ram I can buy from somewhere like best buy that is compatible with my computer (I want good quality Ram).
Thanks a lot,
Ivan
P.S. Please explain the terms you use.
P.S.S. I know my computer is not good but eventually i will end up on upgrading the MoBo & and processor in time.
If you need anymore info from me just ask.
Thanks a lot,
Ivan
