I know it isn't OCUK, but
http://www.scan.co.uk/Products/620W...12V-whisper-quiet-5-year-warranty-NEW-VERSION!
Is very good. I have used scan before (for my own PSU now infact) and they give very quick shipping and very good prices.
If modular isn't your thing then
http://www.overclockers.co.uk/showproduct.php?prodid=CA-011-CS&groupid=701&catid=123&subcat=1084
is also very very good but not modular (imo better without modular as it is cheaper for what is essentially the same thing).
I would say because of the price you can't really get a bad supply, however again because of the price you are able to choose from just about any brand. I would recomen a Corrsair one because they are over 80%, very high ampage on the 12V rails and the 5 year warranty gives you assurance that it will be faultless, not that you need that with Corsair.
Is it for your rig danny?![]()
What are you planning on running on the new Psu?
Here is a OCZ 700w PSU for 72 (I don't have the cool sign button)
Might be worth a look
http://www.ebuyer.com/product/152506/show_product_overview
Danny (i can call you danny, right?) dont forget the Corsair is rated at 50*C, while other PSU's are rated at 20*C. that makes a significant difference!
The HX620W can deliver 50 Ampére on the 12V rail. Have this PSU for, err, 15 months now iirc, the modular cables are excellent, and the PSU works perfect too.(and with 5 years of warranty.. well, I dont think you can go wrong. )\
In the case this powersupply dies tough,.. I'm going for a HX1000W. 9might be overkill, but i'm sticking to Corsair, excellent powersupplies. (the voltages even stay stable at 110% load,.. at least, thats what I've seen in the reviews. )
http://www.ebuyer.com/product/134694
The Cooler Master looks like an excellent deal, the PSU itself looks pretty kick-ass.
get the one i got, http://www.ebuyer.com/product/134695
great power supply, i love mine
dont you think that http://www.ebuyer.com/product/134072# is a big overkill for your rig, or are you planning on building a new rig
too bad they seem to make the processors and grafic's cards more powerhungry all the time :|
Just save money up and get a HX1000Wat least you know you wont make a step backwards in quality.
