sun_kissed_0
There's a CompUSA in brandon which is like an hour or so away.
You are pretty much just assembling parts in a case. There is just a few guidelines you need to follow, which aren't that complicated. Don't listen to these kids that want you to buy a processor so you can over clock it. Like you are going to even get into that? Maybe down the road but over clocking doesn't really improve real world performance, it only really improves benchmarking.
It can make a difference but it is little in many areas and zero increase in others.
BY THE WAY...what's everyone's name so i don't have to keep using your IDs??
Mine's Danielle, if you all didn't know.
man maybe if i put a picture of a girl as my avatar ill get this many replies when i have questions
I build them because I know I can cut corners in certain areas to save money. I could care less about accessories or front panel access.
oh and my name is at the bottom of each article i write at contrail designs, so see if you can figure it out
Do note that online sellers such as Newegg.com can be a lot cheaper.
On the case part, I'm DEFINITELY going to take your opinion. I'm having the most difficult time picking out a case..I'm so picky. Now, I'm definitely going to buy my case at a store.
I really liked this one though...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108064 lol of course.
lol alright adam!
