lastly, that antec 900 is a VERY nice case. many people swear by it. its quiet, and has very good cooling.
Zatharus, thank you for the link. I never even heard of that site before.
How is the Intel Core2 Q9400S Yorkfield 2.66GHz 6MB L2 Cache LGA 775 65W Quad-Core Processor - Retail different from
Intel Core2 Quad Q9400 2.66GHz 6MB L2 Cache LGA 775 95W Quad-Core Processor - Retail? To me, they both have the same processing power but one is $120 more than the other. Is there a difference that is worth the money?
Also, what part is responsible for having a Firewire port? Because having one would be very convenient.
Or, if you want to star with 12GB up front, purchase a 3x4GB set now and a second set later.
Please post a link to these 4Gig sticks of RAM.![]()
How about these: http://crucial.com/store/partspecs.aspx?IMODULE=CT3KIT51272BB1067
Or these: http://crucial.com/store/partspecs.aspx?IMODULE=CT3KIT51272BB1339
*Bonus* Or even these: http://www.crucial.com/store/partspecs.aspx?IMODULE=CT3KIT102472BB1067
Also, here is a bit of fun information: http://www.tomshardware.com/news/samsung-ddr3-dram-4gb-32gb,6933.html
omg lol. OP, do you have 10 grand to spend on your pc? i predict 48 gigs of ram in your future...
zath, you should participate in my outrageous computer building contest in the off topic computer forum. lols.
...it'll be the difference between the quad and the i7, and (I believe) the size of the memory will depend on it also. Unfortanately, I am not really comfortable choosing a motherboard by myself. I have a question about the motherboard dubesinhower had suggested (Asus P6T6 Revolution LGA 1366 Intel X58 ATX Intel Motherboard - Retail). My simple question is, why is it so expensive compared to other motherboards?
The Asus motherboard dubesinhower suggested is rather high priced comparatively mainly because it is an i7 board that supports full bandwidth 3-way SLI (x16 speeds on three ports in a special config.) AND this board also has an on board SAS (serial attached SCSI) controller. Not many motherboards out there have that configuration - especially the on board SAS. It is a high end (enthusiast) motherboard.
For Firewire ports, you can initially look to the motherboard. I would agree, having a Firewire port for audio work it not only convenient, but a must in some cases (audio interfaces, better external storage). If your motherboard does not have one, you can purchase add-in PCI cards for Firewire. I would also suggest looking into eSATA ports as well for better external HD connectivity than USB and Firewire 400/800.
Wow, that's a lot of things that I don't understand...I am quite certain, however, that I will not be using that as this will be just used for recording (Plus my friend suggested that I don't get such high-end gear). Between budget and expandability I would choose the latter, so I will probably go with the i7. I was actually considering this EVGA motherboard (I'm trying to keep the cost of the motherboard under $300). Could anyone make suggestions?
Thank you!
No need for a card... the Antec Nine Hundred has a firewire port built into the front.
That's a good option for you. I would agree with keeping the motherboard cost under $300.Plus this motherboard does have Firewire 400 on-board (IEEE 1394a).
Now, you can go even lower as well. MSI makes a pretty decent motherboard - check this one out.
It does not matter whether or not the case has ports available on it. A case alone will not add the ability to use Firewire. Support for it comes from the motherboard or an add-in card. If the motherboard does not have support for Firewire built-in, you will have to purchase a separate PCI card. You could then run the interface cables from the front panel port to the PCI card in that instance.
