dark666apoc
check out the big typhoon from thermal take
: or the blue orb my honest opinion unless you are SUPER overclocking most of the heatsinks out there are the same
you can only dissipate so much heat from a processor with air so these 80 90 dolalr heatsinks arent even worth it
my 40 dollar bg typhoon works JSUT as well overclockign as say a v10 (which my neighbor has jsut gotten) they lowered temps from our 5200s pretty much equally he had a 50 mhyz higher overclock then me and got the same temps
so in my opinion jsut get somethign that will fit and lowers temps by about 10 or 15 degrees thats about as good as you will get
btw his house uses a/c mine does not (poor bitch
) lol
