Irishwhistle
...when I install Windows, or is it saved to my Steam account? Thanks!
If you can open steam through ubuntu then there is the option to right click the game and then click create backup.
If you can;t do that all .sav files are, strangely enough, save files. Back all then up and make a note of where they go and then if you put em back you should be good to carry on as you were
be careful with that, i did that when i swapped from vista to 7 back to vista and ended up losing everything
