Aastii
I am having system crashes and i know for a fact that it is to do with my memory. It only started when i upgraded my RAM from 2GB corsair memory to 8GB OCZ memory.
I am on a 64 bit os so all should be used, i have ran memtest overnight several times and that finds nothing, i have flashed my bios to the most recent a couple months ago and that did nothing (it is still at the most recent), have run several stress tests with nothing found.
I know it is the memory not only because it only started after the upgrade, and i had more issues than i care to count getting it working, had a load of OCZ workers helping me to get it fixed, so now seems a good time to say, if you ever need OCZ support, they are excellent for it. It is because aswell as freezeing i have also had a couple of bsods with the messages MEMORY_MANAGEMENT and PAGE_ERROR_IN_NON_PAGED_AREA both of which i know are related to memory issues.
I am now lost for what to do and was wondering if any of you had any ideas.
I think i should also point out that when the OCZ people were helping me out they mentioned to change the NB and memory voltages. I changed them to what they said and it made the system more unstable than before, so could it be a voltage issue?
==EDIT==
Also i am wondering, because i am on 64 bit vista then not only should all 8GB used but the programs should allow all of that to be used on program shouldn't it? The programs like memtest and IBT i used for testing only used 2.7GB of RAM each, so i had to run multiple memtests at once rather than one at all unused memory like i would on my 2GB system. Is this supposed to happen or could it be i have managed to get a 32 bit verion of the software or does 64 bit still run under the max memory for each program rule as 32 bit?
==EDIT==
