somerled76
Hello all.
I have just upgraded my Dad's PC from a AMD Athlon 1.53Ghz A MSI MS-6340M Motherboard with 736MB RAM, to a new AMD Athlon 64 on a Biostar MCP6P M2+ motherboard. I removed the old motherboard and inserted the new one with out issue, connecting all of the internal devices. The only thing I was unsure of, was connecting the HDD and the CDWR using the same IDE cable. Not sure if i needed to upgrade the HDD to a SATA. I throughly checked all connections etc a good few times.
On start up the machine switches on the HDD led lights, the fans run and then nothing. No sound, nothing on the monitor, no start up sequence or any thing. I was hoping that it was just going to be a simple case of plug and play!
The operating system-XP Home- is on the HDD which hasn't changed.
Any suggestions would be most appreciated.
