Those cheaper ones... maybe better than stock, but not what i would consider to be "good". As far as "cheap" goes, this is prolly the best one over there for the price:
http://www.ebuyer.com/product/105994
The freezer Pro is probably the best "cheap" CPU cooler around. I had one on my E6300 and I was idle in the mid 30's and full load in the high 40's / low 50's. Probably worth saving a little more to get that. Though the push-pin design is a little annoying and doesn't really give you much confidence when moving the case around. Do you regularly move the case? If so, I'd probably look at something else, something with a backing plate.
You might be able to ghetto mod your own backing plate onto it, but I can't guarantee it'd work. Plus, I guess you don't really want to save up and then potentially break it.
If you're not going to be moving it around much it'll be fine with the push pins. You're using the stock Intel cooler at the moment, that uses pins and you've not had any problems with that, right?
no no dont go with Akasa....i had one of their cheap blue led coolers when i first got my core 2 duo e6300 and it was not very good.
To be honest,if you want to get decent temps with an overclock you will need to go with something like this
http://www.ebuyer.com/product/153202
I had a Artic freezer 7 pro before my current cooler and it was okay for the price but i needed better.
