If you don't mind the price, this one is pretty nice:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
Will that fit in an Antec 900?
Yea I I know but it's $70 the other one is 55 why should I buy that one? What's so good about it ?
Take a look at the Xigmatek S1283 dark knight, excellent cooler for the price:
	I don't like how there's big gaps between the pipes and the block.
considering that most of the heat transfer takes place through the heatpipies, the design may very well be superior having the pipes directly on the CPU as in that pic. whenever you have extra metal between the things you want to transfer heat to, you get more resistance to the transfer, resulting in a higher temperature difference (ie the processor is warmer)
That's not what I'm concerned about.
My point is that there are Gaps between the Pipes and the Block, as shown in my illustration.
You'd have no choice but to spread your TIM first. It may work well, but not for me.
