somerled76
Hi all,
Here's what I've done and tried.
1. Replaced the Old AMD athlon and mobo with a new mobo and AMD athlon 64. Removed floppy disk drive(original set-up) and USB, LAN cards(that i had previously added).
2. Tried using the OEM disk to no avail. Realised it's not the full XP disk.
3. Got a copy of XP, tried rebooting the system. Didn't work.
4. Put the machine back in it's previous state-original mobo and AMD athlon, minus the LAN, USB and Floppy drive. (checked and double checked IDE cables in every possible combinations) Machine switches on and boots into windows XP home ed.
5. Tried using OEM disk to reboot to factory settings. (Has worked no problem in the past) no joy!
6. Reset CMOS and bios settings as these had been changed to boot from CD.
7. Seems machine will not read CD's any more! DVD's no problem.
8. Down-loaded new firmware for cdrw/dvd. Guess what no joy.
9. Just tried a lens cleaner-the cd type-but it wouldn't recognise the disk, which was supposed to play music.
10. The drive doesn't recognise any files of any format, inserted into the drive, other than DVD's.
11. Deleted all unneccesary files in case that could help.
12. Just oredered the same cdrw/dvd drive from ebay to eliminate that issue.
13. I've got a sore forehead from banging it against the wall.
14. What else to try?
A new hard drive?
A new cdrw/dvd?
Other booting software?
I should have prob. just bought an entire new set-up.
A new hard drive?
A new cdrw/dvd?
