Help still required, not sure what to try next! A challenge for you.
somerled76
Hi all,
Here's what I've done and tried.
1. Replaced the Old AMD athlon and mobo with a new mobo and AMD athlon 64. Removed floppy disk drive(original set-up) and USB, LAN cards(that i had previously added).
2. Tried using the OEM disk to no avail. Realised it's not the full XP disk.
3. Got a copy of XP, tried rebooting the system. Didn't work.
4. Put the machine back in it's previous state-original mobo and AMD athlon, minus the LAN, USB and Floppy drive. (checked and double checked IDE cables in every possible combinations) Machine switches on and boots into windows XP home ed.
5. Tried using OEM disk to reboot to factory settings. (Has worked no problem in the past) no joy!
6. Reset CMOS and bios settings as these had been changed to boot from CD.
7. Seems machine will not read CD's any more! DVD's no problem.
8. Down-loaded new firmware for cdrw/dvd. Guess what no joy.
9. Just tried a lens cleaner-the cd type-but it wouldn't recognise the disk, which was supposed to play music.
10. The drive doesn't recognise any files of any format, inserted into the drive, other than DVD's.
11. Deleted all unneccesary files in case that could help.
12. Just oredered the same cdrw/dvd drive from ebay to eliminate that issue.
13. I've got a sore forehead from banging it against the wall.
14. What else to try?
A new hard drive?
A new cdrw/dvd?
Other booting software?
I should have prob. just bought an entire new set-up.
Hi all,
A new hard drive?
A new cdrw/dvd?
Since you changed your motherboard you can't use the existing installation of XP on the new motherboard, you would have to do at least a repair install. But I would recommend a fresh installation. Go into bios and make sure cd is set to boot first. See if you can boot to the xp install cd.
take everything off the mother board leave cpu and dimms in try and see if it post, you dont need hard drive for it to post nothing happen.....take out sims and listen if you get any beeps... report back here and let me know... make sure the P4 connector is on the mother board
I have tried that a handful of times and still no joy.
Can I clear a couple of things up, i've come across 'post' quite a bit but don't fully understand what it means.
dimms: memory?
Sims?
P4 connector is that the 4 pin power connector?
Sorry for my nievity.
When you say take everything off the mother board do you mean all connections e.g. monitor, mouse, keyboard, front connections(reset, power led, hdd led, speaker), all fans?
What about the CPU fan?
dimms: memory?
Sims?
POST=Power On Self Test, the test you see running before the OS starts loading.
If you changed the CPU and motherboard, you could have a bad PSU.
By POST, they mean will the BIOS post.
How much RAM do you have? How many sticks? Are they in the right slots?
How can I test the PSU?
The new mother board has a 1gig stick in the first slot.
I take it the sims are the RAM sticks, should I be doing this whilst the machine is running?
