bomberboysk
Newegg ships stuff in multiple boxes, ex- the case they ship in its own box, my cpu came in its own box, some stuff is combined into the same box though.
OK, now that I am ACTUALLY buying this stuff, some prices have changed so I have a few more questions about alternative parts (listed in order of importance):
PSU:
Is this PSU any good? http://www.newegg.com/Product/Product.aspx?Item=N82E16817341012
This one went up in price: http://www.newegg.com/Product/Product.aspx?Item=N82E16817703017
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122 or with slightly worse timings, more advertising crap:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227362
Mobo: Some other possible options (GB P-31 is $63)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131329
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128357
Got this case instead of Coolermaster:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147113
For the price a hec power supply would probably be the better bang for buck.
Thanks a lot for the quick replies! I think I am pretty much settled thanks to all the help!
bomberboysk - thanks again, and also for the promo
oscaryu1 - Any particular suggestions for a Hec PSU? Keep in mind that OCZ is $50, but drops to $30 w/ MIR...
However, this looks tempting: http://www.newegg.com/Product/Product.aspx?Item=N82E16817339025
OK, well I didn't read the whole thread (just the beginning and the end), so here's my take on it... forgive me if I missed something.
First, why not save money and get a case with free shipping? Here's three to pick from:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147114
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119193
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156223
Also, have you considered AMD? I've found that it seems to always be the best for budget system... you just get so much more for your money. Either of these, for example:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103678
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103300
I'm personally very pleased with AMD... and (really minor thing, but whatever) their stock coolers seem to be nicer quality than Intel's.
You could also save money with onboard video... ATI Radeon 3100 and HD3200 seem to be very nice for what they are.
EDIT: OK, I see you've made some changes, and you've already bought the case and GPU, so you can ignore those two recommendations.I'd still highly recommend AMD though.
Great! Thanks again guys!
Irishwhistle - I am biased because I have always run Intel, but I really appreciate the suggestions. The main reasons why I am tempted to stick with intel are 1) 45nm, and specifically the E5200 can OC like crazy (4+ghz for a $70 CPU!!) and 2) I am pretty familiar with intel components and architecture compared to AMD.
bomb - funny you mention the p31. If you look at my original build, I had that same board, so maybe I will end up with it after all. The p5q is a bit out of my price range, and possibly a bit overkill (if such a thing exists) considering the purpose of this machine (internet browsing, etc.), but thanks!
OK, I understand... you should still give AMD a chance though sometime.![]()
Hi guys,
I order everything, so it's in the mail finally.
My case got here today, the Rosewill Wind Rider.
It seems quite nice for $40, but there seems to be one idiotic flaw: the front mesh cover, which is magnet latched, has to be opened in order to access the front USB and audio ports. Also, I've only looked at it briefly, but it seems the pannel must also be opened to open the DVD drive.
Can anyone explain why they might do this or correct me if I'm wrong?
