well, i was thinking about 2.5 thousand for the computer. We're going to be recording church services in HD, editing them, and making dvd's for people
Wow, thanks, i like it. So this will pull video editing with ease, right? well i don't need the os, display, mouse/keyboard. and is the video card like 2 in 1? is the performance better when they are together like that? Because i dont think i'll need the 4 outputs, probably 2 at max.
Ohhhhhhh.... then this'll be no problem to come up with a list.
Give me a bit and I'll have a list for you.
EDIT: OK, here's the list:
CPU: Intel Core i7 920 2.66GHz
Mobo: Gigabyte GA-EX58-UD5
GPU: Sapphire HD 4850 X2 2GB GDDR3
PSU: Corsair 850W
RAM: OCZ 6GB DDR3
Case: Cooler Master HAF 932
HDDs: 2X Western Digital Caviar Black 1TB
ODD: LG Black 22X DVD Burner (I'm not sure what you plan to use for disk burning and duplication so I just included a fairly basic drive in the list... nothing special.)
Mouse/Keyboard: Logitech S 510
Display: Acer 24" HD Widescreen (Should do the trick, look around Newegg is you want something special.)
OS: Windows Vista Home Premium 64-bit
Grand Total: $1,832 + S&H and it's a very nice system indeed. Since it's a good deal below your max price there's room for improvement if you want it (like for DVD duplication and the monitor.) Also, you'll need something for sound if you don't already have something... a nice pair of proper headphones should do the trick though.
Nice list.
However, single 4890 ~ 4850 x2, I suggest getting 4890/ GTX 275.
if you're running pretty intense cideo editing maybe get 12gb of memory since you got the extra money anyways
I would spend money on high speed high quality hard drives, they are going to be your slowest component.
I have read that hollywood block buster movies have been edited on Macbook Pros before, and they can only hold a max of 4Gig of RAM.
Macbook Pro 8Gigs of RAM.
http://store.apple.com/us/configure/MB604LL/A?mco=MzA3MTE3NA
what about solid state drives, what if i get those? and is it worth getting a mac?
If you want to get into Final Cut Studio, Logic Audio, and Shake, then get a Mac. Those are Mac only apps and some of the best at what they do. There are only a few really good high end video editing apps that get used in the professional world of TV and Movies, and Final Cut is one of them. It really boils down to what plug ins you like the most since most video editing apps run the same but their plugins is what makes the differences to some people's preferences.
I mean if you went out and got video toaster and used it and loved it, which is PC only then maybe you want to build a windows box. If you like Final Cut and Shake then get a Mac.
If you use adobe you can get whatever you want since they run on both Mac and PC.
There are many pros to using a Mac but you will have to decide for yourself what is best for you in the end.
