6gb of ddr3 1333 for $100 isn't bad, look here. And thats before $10 mail in rebate with free shipping.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145220
actually it is bad, when you can get 1600mhz for similar price
http://www.newegg.com/product/product.aspx?item=n82e16820231247
You can use any 3 same sized (ie 1GB) sticks of RAM that fit in the motherboard for triple channel. You don't need to buy a special kit if you don't want to.so does that mean i can't use 3 1gb sticks that used to be in a dual channel motherboard, on that motherboard i posted?
Okay, nice to know!
Well, depends on exactly what memory also, as older legacy ddr3(above 1.65volts) poses a risk to core i7 processors as the memory controller is on the cpu die, not the motherboard.
