leopardforest
I am going to get a GTX 275 and I would like to run SLI in a couple months. I plan on getting a Corsair 850, would that be enough power?
the rest:
i7
room for 3 hdd
the rest:
i7
room for 3 hdd
The GTX 275 isn't on this list yet, but I think you could squeak by with that psu,
but you may want to consider a 1000Watt instead.
http://www.slizone.com/object/slizone_build_psu.html
Well I thought Nvidia would know better than you or I what to use.I cant really speak from experience, but that just seems like overkill (referring to that link) compared to what people are using?
I can't find an SLI "Minimum Requirement" for that card, which is what you're looking for,Minimum of a 550 Watt power supply
(Minimum recommended power supply with +12 Volt current rating of 40 Amps.)
??? wrong thread dude, but the GTX 295 can somewhat do it.is there any single card that can completely max crysis out? i mean completely max it out?
GPU - NVIDIA GeForce 8800 GTS/640 or similar
Somewhat? I can play Crysis maxxed out on my GTX 260 at 30-40 fps,
so I'm sure the 295 can more than "somewhat" handle the task.
Crysis Recommended System Requirement:
Also, the GTX 295 is not considered a single card, it has two gpu's.
Well I can, and that was my point, so nVidia ftw. :good:i cant max out crysis even with my 4870x2 so thats why i stated that the GTX 295 can somewhat do it.
And 850w will be more than enough to run those 2 cars in sli. You would have no problems what so ever.
Er note quite,,,,I just bought a second GTX275 hooked them up in sli on a 850w supply, All Was going great while i gamed of the hard disk , But then i put in Grid (which required the DVD rom)
Needless to say i am now in need of a new damn psu 60 quid down the toilet it just damn killed it id had those cards in there about 30 minswhen they say you need 40amps on the rail they mean it trust me
dude that sucks. what brand of power supply was it?
ouch, it was an offbrand so what can you expect.. but a single rail is better than one. a corsair 850 would be enough, since it has 70 amps on the +12v
you think 70 is enough to handle the 4-6 drive raid + 965 quad ?? , The 275 manual states 40amps per card , and isnt really clear if its just for the card or for everything?![]()
that means 40 amps is reccomended for the entire system, including the card. the card itself only uses around 15-22 amps. so a 70 would be enough. but only a good brand, like corsair, pc power and cooling, seasonic, silverstone, ocz.
how about this fellow ???
http://www.scan.co.uk/Products/1000...d-PCI-E-6pin-ATX-12V-22-and-EPS-12V-Std-80plu
oh yea, thats more than enough. and a dang good price too
