New athlon 45nm dual cores.(250 and 245)
bomberboysk
This cpu's look pretty sweet, i think i might get on if they are under 125$
http://www.fudzilla.com/index.php?option=com_content&task=view&id=13564&Itemid=35
But will these cpu's be backwards compatible with my older am2 board?
I know they are ddr3 so does that mean i have to upgrade my mobo and such?
Does anyone know?
As long as your board has a bios update that allows them then you are good to go;)And better yet, Amd is finally comming back ahead like they were when intel was in the pentium 4 days:good: Gotta love backward compatibility...(Thanks i7 for changing sockets:mad:)
nivan
I think 250 cpu is for am3 socket and not for am+.
Anyway i think now we will see low cost am3 motherboards.
Now i don t think you can find am3 motherboard under $200.
StrangleHold
Moderator
AM3 processors will run on AM2+ boards if they have a bios update. Its the other way around AM2+ processors will not fit a AM3 board. Plus there alot of AM3 boards for under 200 bucks.
mx344
Cool, looks like theres hope for my current mobo, hopefully they have a bois update :), the last update they had was for the 7750.:(
Gooberman
Are you saying you can't find any AM3 boards under $200?
Jamin43
banned
Hey I've got an Intel 4. You tellin me those days are over :p
Jamin43
banned
