think i bought a lemon of a laptop
dcjcdc
bought a used acer aspire 5000 laptop
when you turn on computer , screen is blank...so nothing is loading on
tried f8 nothing....
it came with no cd's
was thinking of ordering a new hard drive for this..not sure if that would help
thanks
suggestions to get it going
take it back or send it back to where you bought it. Or send it back to the manufacturer. It should have a warranty if it's new.
Turn the computer all the way off, unplug it, remove the battery, plug the laptop back into the wall only and power it on. Do you see anything at all on the screen like the POST test? Do you hear any beeps?
thanks for the response
tried it
no beeps or nothing..blank screen with power button on
bought off ebay...
Ouch.
i don't think there's much you can do that will give you satisfactory results... I suppose you could gut it and build it again yourself...
