Is this a good build?
.sirhChris.
I'm going to be using this PC for (listed in order of importance and frequency):
.Home and school use (Internet browsing, Word processing, maybe PowerPoint)
.Beginning Video Editing (using AAE CS4, Vegas 8.0, GIMP)
.Video capturing Halo 3 from the Xbox 360 (probably with external SD capturing in the beginning, might move on to an HD internal capture card or external HD cap card)
. Gaming (Halo PC, H2V MAYBE[I don't PC game, I don't own any PC games])
I have a budget of $1,000 and less. $1,000 is stretching it. Please, make it as powerful as possible without nipping too much at the budget. I am interested in montage editing and will build this with my dad.
/copyandpaste
Alright, my other thread is irrelevant and is dead. My question is, is this a good build for my purposes?
Improve it without going over $800 in the subtotal if possible.
Your cutting it pretty close on your psu check into another one thats a little more powerful id recommend a corsair they make really good ones check into the 750W one and dont forget your opperating system unless you already have it.
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
or if you dont mind rebates
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341019
GPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127420
HDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136359
Case, save some munez on shippingz!
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119077
Drop monitor to this, pretty much the same monitor, plus spdif out(useless feature unless your using something like a ps3 through hdmi, but its cheaper and pretty much the same display)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236053
Memory: (cheaper than the combo there)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231241
Dont see an odd in your list? This is a good one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188
With these changes and an odd added, subtotal is $801.91(dont forget the free shipping on the case saves $10-15)
Thank you bomberboysk.
Only thing is that I'll need a DVI-HDMI adapter... :(
Well, I could just run down to Worst Buy and grab a DVI-to-HDMI cord anyway.
looks good and if you can afford it i would strongly recommend upgrading the video card to a 4850 or a 4870.
Not worth it when hes not a gamer, the 4830 is almost more than what he really needs tbh, but since its only a $10 or so difference from a 4670 then why not futureproof a little bit.
Ehh, I don't care much about shipping cost, so I'll actually stick with the Antec Three Hundred case. I'm not too sure about that Cooler Master, I'd rather take the time to build a sturdy case with screws than have a flimsy plastic part break off and not be able to have it fixed. Screws > tool less.
That coolermaster is an excellent case and very sturdy, as is the three hundred. Cant go wrong with either choice;)
