Hi guys. I am new to this forum. Currently, I have an Asus 9500 gt video card and I was wondering what card would be a good upgrade that is around $130? Any suggestions would be great.
Thanks
What are the rest of the specs of your system? Cpu/mobo/memory?I have an Antec True Power Trio 550w psu. Which of these cards you guys had recommend would be the best?
i think that it's betweent the gts 250 and the 9800gtx.... the 250 is a renamed 9800gtx but since it's a newer card and has better driver's it will probably be slightly better.... I say go for the 250 but if you could dish out another $30-$40 maybe you could go for a gtx260
ok but the 250 has probably has some bug fixes and such on the cardWhat are the rest of the specs of your system? Cpu/mobo/memory?
They use the same drivers...
E6300 1.86ghz cpu
P5QL-Em mobo
4gb ram(unknown brand)
Which would you recommend bomberboysk?
You care to explain that.
Currently I am stuck between the 9800gtx+ and the gts 250, but I am leaning towards the 9800gtx+. What do you guys think?
