holyshit
This is the cpu i am buying http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649. But i was wondering since its a triple core how many ghz are the 3 cores in total?
Yeah thats true. Anyways i asked this question because my friend told me that one core could be 2.8 and another could be 1.2, that true?
Yeah but is one core less powerfull then the other?Yes, if you use AMD Overdrive software you can clock each core on its own .
Then what do you do? I mean dont they work as one machine.
Thanks for help. But the cpu good enough to play games(thats why i was worried).They can but it just depends on how well the program/game is multi threaded.
cores can b clocked independently?
I take it it cant b done in the bios.
nice 2 expand my knowledge, but i personally prefer 2 OC in the bios.
