the power is really a 200w/700m i dont know what brand yet
Wouldnt worry about it, some china offbrand it sounds like.its a newtron i cant read the model number or name ill take it out tomorrow
A 200 Watt power supply likely isn't adequate and it is poor quality. If you use a cheap power supply you could possibly damage the components you are going buy. Get the XCLIO GOODPOWER 500 Watt Power Supply Bomberboysk suggested. It is good quality.
XCLIO GOODPOWER 500 Watt Power supply - $45
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
Personally, i would do something like this:
ODD: http://www.newegg.com/Product/Product.aspx?Item=N82E16827140038 (Out of stock for now though, most of the sata optical drives are outta stock)
Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128382
PSU:
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147109
Memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220255
HDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
Just use integrated graphics for now, then later once you have some extra budget go for something like a 4650/4670, the 8400 isnt a whole lot better than the integrated graphics on the motherboard in this list, as it has some pretty good integrated graphics on it.
I kinda did that like 15 posts backWith that you have plenty of room to upgrade gpu in the future, and ride on integrated until then. HD3200 are pretty good as far as integrated graphics are concerned.
Whoops, forgot the link:what about a cpu?
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10010065&prodlist=celebros
Better than the 8650 for ~$15 more, trust me, tis worth it![]()
Triple core, 45nm, overclocks like a beast.how many processors?
Lol, i think i have enough of thosenvm i found it, and i think i meant was cores and it has three.
the total with shipping for all of this is
$329.73
i thick i can get enough money for this
im selling my old laptop and ps2 slim on crigslist let me know it you want to buy lol
Lol, i think i have enough of thoseGood luck selling em though
At lower settings yes, with a good gpu like a 4890 can prolly play on higher settings depending on resolution.thanks for all the help
well this be able to handle gta iv if i get better gpu
Every thing you have picked is very good trust boomer about the 8650 it's what I have and I'm not to happy with it but I will be upgrading to a Phenom II 940 or so in a couple months.
First is because I payed $90 for it at eBay then I started using newegg and found out I could have got a way better CPU for like $20-$30 more. Also it's a little weak for me I do a lot of music/video editing for my band and it cant handle the big programs I use when I'm editing I sometimes have 5 or 6 programs opened at one time and my computer gets really slow. I am hoping once I get my new GPU it will handle it a little better.
