Aren't almost all, if not all X2's just dual cores or do they turn some X4's with bad cores into X2's?
The Phenom II X2 is a quad with 2 cores disabled. The Athlon II X2 is just a dual core.
Hmm so all are just disabled just to be a dual core or could you get one that has 1 or 2 bad cores?
Now that demand is somewhat lower, there are enough bad cores to fill in. Chances to unlock are pretty low.so how likely is it thay ill b able to unlock the cores?
If you do, go for a 720 BE as if it doesnt unlock, you can still get a good oc out of itWell is it still worth givin it a shot?
