I'm inheriting a new processor, need advice!
If you wanna spend a bit more, for around $145 a 4870 1gb can be had:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150394
Or a 4890 for around $200, $170 after rebate:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127427
Any of the ram would work, yes;)
I don't mind spending a little extra getting the 4890, but the newegg reviews say the things is loud as hell. Should I be worried?
Also, which version of windows would you suggest I buy for this system?
Excellent choice with that card, it has some kind of capicator in it that supposedly helps overclocking, and a much better fan setup. For windows, get the "Windows Vista Home premium" 64bit, the one with the "tech guarantee", as it includes the windows 7 upgrade ticket(will be noted on the os)
Alright, this might be it. I'm getting nauseous just thinking about the final bill. :eek: Let me know if you would do anything differently.
I guess my final question is, am I putting too much money into a system around this CPU?
MOTHERBOARD
ASUS Rampage Extreme LGA 775 Intel X48 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131334
HEATSINK FAN
Cooler Master V8
$59.47
CASE & POWER SUPPLY
Antec Signature 850
Antec P183
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.208554
RAM:
Patriot Viper x2 for 8 gigs
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220344
VIDEO CARD:
ASUS ATI Radeon 4890
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121308
WINDOWS VISTA BUSINESS 64
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116676
DVD DRIVE
Sony DVD CD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
HARD DRIVE
Western Digital Velociraptor 300 Gig
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136296
Total Damage: $1442.40
That will be a very nice computer...you will not be disappointed:D
Not really what I would do, but if you ask 100 people they will give you 100 answers....as you have already seen in this thread;)
Thanks for the words of encouragement Scout, I really appreciate it!:o
Alright, so I did A LOT of research and I decided to flip the script on my previous build idea. I discovered that I might be overspending on my previous components versus performance increase. The system will now cost me just a bit over a grand.
You guys have been a massive help to me and I would greatly appreciate your feedback on this proposed build. I'll have to order by tomorrow to lock in the sale prices.
MOTHERBOARD
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
$134.99
$114.99 after rebate
HEATSINK + FANS
Prolimatech Megahalems + Noctua NF S12B FLX Fan
http://www.heatsinkfactory.com/prolimatech-megahalems-cpu-cooler.html
$83.98
CASE & POWER SUPPLY
Antec Signature CP-850
Antec P183
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.208555
$225.45
RAM: 8 Gigs
(2) G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1100 (PC2 8800) Dual Channel Kit Desktop Memory Model F2-8800CL5D-4GBPI - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231194&ref=dynamitedata.com
$64.99 x 2 = $129.98
VIDEO CARD:
$190.00 after rebate
WINDOWS VISTA HOME PREMIUM 64
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116677
$109.99
DVD DRIVE
Sony DVD CD Burner
$32.00
HARD DRIVE
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
$99.00
Because I could get in deep sh*t if I sold it. I'll leave it at that;)
From what I'm discovering DDR3 is at most *marginally* faster than DDR2. Most of the time the difference is negligible. Unless you get crazy expensive very high speed DDR3 RAM then you might see a few percentage points.
Two articles, one from anand and the other from xbit labs both conclude that at the same Mhz there is very little difference. [Note: both articles are from 2007 when DDR3 launched. Speeds topped out at about 1333mhz].
http://www.anandtech.com/memory/showdoc.aspx?i=2989
http://www.xbitlabs.com/articles/memory/display/ddr3.html
Then I saw this article from Anand in June of this year "Memory Scaling on Core i7 - Is DDR3-1066 Really the Best Choice?". Up to 40% better in synthetic benchmarks, but it didn't translate into realworld applications.
http://www.anandtech.com/memory/showdoc.aspx?i=3589
To quote from the article "Once again, as we moved to real-world applications, those impressive synthetic benchmark improvements did not translate into results that would justify spending three times as much for a memory kit for most people. We had mixed with certain applications like WinRAR producing a 20% improvement from DDR3-1066 C7 to DDR3-1866 C7 while several applications showed minor performance improvements under 2%. If your primary job is to compress and archive files for a living, then the expenditure for fast low latency memory is justifiable."
If I was building an i7 platform, then yes DDR3 all the way. Or an AMD AM3 socket build. Otherwise, nice fast DDR2 seems the way to go. I'm still going to check out your recommendations and see if that might be a better way to go. But a few people I've spoken to who own a qx9650 (which my qx9750 is very similar to) swear by the Gigabyte board.
Well, X48 overclocks somewhat better than a p45. DDR3 way back when it first came out wasnt worth it over ddr2, as it had high latencies. But now, you can get 1600mhz ddr3 for relatively cheap, at good latencies. Plus, if you ever go crossfire...X48 is electrically x16/x16, while P45 is electrically x8/x8 (not as relavent now as it will be with the 5xxx radeons though, and also it can bottleneck it if your running at anything higher than 1280x1024).
