Post A Pic Of Your Pc Here :)
heres what I came up with, I'll put up some general measurements but I would measure according to how tall you want it and whatnot.
Just a little tip: Get some long drawer slides for the keyboard tray. That way you can slide it away when not in use.
I got 100lb drawer slides for my keyboard tray. I could sit on my keyboard tray no problem.
You weigh less than 100lbs?
I believe you would add each side together for a total support of 200 pounds but I'm probably wrong about that.
Plus, rated for 100lbs means they can prolly handle more than that..they are just rated for 100lbs. Also, youd of course need to subtract weight of drawer, etc.
