ScottALot
Hey!
I'm making a build for my 1st customer. He's on a budget, so I found a list of parts used by a youtuber and they looked real nice for his budget.
HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822136071
OD http://www.newegg.com/Product/Product.aspx?Item=N82E16827106328
RAM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814125095
CASE http://www.newegg.com/Product/Product.aspx?Item=N82E16811208005
(and 2 120mm fans) http://www.newegg.com/Product/Product.aspx?Item=N82E16811998122
I have to find a CPU and a motherboard, but the one's he used are not on NewEgg or Google. The YouTuber used an Intel E4500 2.2GHz Dual-Core and a Gigabyte GA-P35-DS3L mobo. Can you find me some substitutes? And if some of the parts I'm using are really bad, just tell me a replacement, but please don't go too far out of price range.
