funkysnair
well i tried for a while to see if i could get 4ghz, i reached 3.9ghz but was unstable and i did not want to give it too much voltage!
i do realise that the co stepping is not the best overclocker next to the do stepping but i did reach a modest 3.8ghz stabble!
i am a overclocking novice so it took me some time, a couple of voltage adjustments (1.26max for cpu 1.65 max for ram)
i wasnt going to go any further than that for sure!
i have now dropped it down to 3.6ghz and benched it some pics.... (1 gpu xfx4890)
i also overclocked the gpu-GPU CLOCK 960mhz MEMORY CLOCK 1100mhz
http://i108.photobucket.com/albums/n37/funkysnair/38stable.png
http://i108.photobucket.com/albums/n37/funkysnair/3dmark.png
if you guys have anymore tips or anything let me know thanx
p.s i also noticed that throughout the overclocking process my temps at full load stayed very similar give or take a few degrees...
i belive that it must be something to do with my fan/radiator combination, some radiators work well with mid-low speed fans whilst some do better with high speed fans!
i think i have a nice balance as the max i get is 60c at 3.8ghz under prime95 and i get 55c at 2.6ghz under prime95
