Post A Pic Of Your Pc Here :)
@ Fatback, you might wanna fix the resolution on that big screen ;)
My resolution is at 1024x768 which in the manual is the recommended for my TV when I try other resolutions then everything looks small and out of proportion.
ha, send one my way if you got too many >.<
There is nothing in there you would won't most of them is P4 and P3 systems expect for 2 that have lower end core 2 duos
That's odd, it should be 1360x768 if your TV is 720p. :confused:
The odd thing is my TV is 1080P but in the manual the recommande res for PC's is 1024x768 even stranger my computer dosen't even give me an option to pick 1360x768 as my res only 600x480, 800x600, 1024x768, 1152x864, 1280x960, and 1280x1024 and this is coming from catalyst control center.
How do you have it connected?
That's probably it. It's likely that it only accepts those resolutions over VGA. If you got a DVI to HDMI cable it would probably do 1080p.
Yea that's what I was thinking because when I was using the onboard graphics with HDMI 1080P would show up but since I installed the 4850 it's gone. Do you think it would be better for me to use HD component cable and the adapter that came with the card.
The quality probably wouldn't be as good as with VGA, but you can give it a try if you have a set of cables lying around, and see if it allows for 1080p also.
I will try that soon the weird thing is I just went to display setting in the control panel and 1360x768 was there but when I tried to change it there was no picture until it switched back to 1024x768 weird.
Here is my i7 Rig
Antec 902 Case
Gigabyte EX-58 UD4P
Core i7 OCed to 3.8 with CM V8 (Scythe Fan)
OCZ Platinum 1600 6GB
ATI Radeon 4870x2
Enermax Infinity 720W
What you guys think ?
